Time machine and AC86U
jamjam8910
Hi everyone,
I thought I’d post my findings with TM and the AC86U for those that have been struggling to get this to work.
I’d be interested to know if this is what has fixed it.
I was getting constant hangs and failures with TM backup and my 4TB Seagate One Touch.
doing the following seems to have made everything work though:
  1. formatting the drive into 2 x 2TB HFS+ partitions using disk utility
  2. In one partition, creating a folder using AC86U called Backup
  3. Mounting that folder in MacOS (10.13) as a connected server
  4. Enabling time machine on AC86U using that same partition
  5. Selecting the backup disk that appears in time machine to complete the first backup via LAN
  6. Backup completed (first time this ever worked for me)
  7. Ensuring to Mount the Backup partition before running TM incremental backup
If you also find that this works for you, I’d be keen to know.
cheers
