Michael R Stamper
Hi - I’m using the RT-AC3200 with Merlin and YazFi to have a dedicated VPN SSID. I am thinking of upgrading as my new condo has fiber coming in by the front door and all of the devices are on the other side of the condo through walls - there is a bathroom and kitchen between the router and the living room.
While the place is small - 84m^2 - I’m worried about he signal going through all of the walls. It’s not possible to just hard wire through the walls without major surgery.
I see Asus has some Mesh and VPN Fusion tech - so will 2 routers that support these capabilities give me a solid signal through the mesh and a dedicated VPN SSID without using YazFi?
If I use mesh will Merlin still work? Will YazFi work with Mesh enabled (assuming the VPN Fusion function for some reason is inferior?).
I appreciate any advice - I’d like to think I would just need 1 router at the front of the condo - but if 2 are required I’m trying to figure out how to get the YazFi capability of having a dedicated VPN SSID working with YazFi or using the Asus VPN Fusion capability either mesh mode (I hope I don’t need this) or not.
Thanks for your time in providing advice.
