Time to upgrade RT-AC68R H/W Ver: A1 from 380.59
DroidST
Now running a RT-AC86U with 384.8 Beta2 as the Primary and satisfied with it, now up nearly 4 days including connected clients to it).
The 68R has served my network well as the Primary for years along with two linksys routers running DD-WRT as repeaters. It's time to replace the linksys routers with the 68R.
If I remember right, once I upgrade the 68R to 380.60+ (I will go to 384.8 Beta2 from 380.59 though, after doing a Restore on it), I will not be able to go back to 380.59 on that 68R, unless I use Asus' firmware recovery tool. Is that correct?
Or, have they restricted doing that even with that tool?
Yes, you are correct! :cool:
But do NOT restore settings on different versions of the firmware - re-enter it manually. :rolleyes:
