RT-68U
I've had no clients that have been able to connect to my Guest Network (2.4 or 5ghz) since 376 firmware. I'm running 3.0.0.4.378_3873 now but same problems.
Windows and Android clients see SSID, but after I type in key (WPA2 or WPA) they just say they cannot make connection.
I've done a hard reset many times now, before 376 and before 378. Manually re-keyed config all times, no restore from config.
>> cat /dev/mtd0ro | grep bl_version
bl_version=1.0.2.0
This is the only problem I'm having, 12 other 2.4ghz/5ghz clients are just fine.
Does anyone know any other logs I can tail on from Asus side?
Asus support is shooting in the dark and wants me to go back to 3.0.0.4.374.371 and make my way up from there until it breaks.
Thanks!
bl_version=1.0.2.0
Thanks!
