TP Link ER605 - DNS config for devices
autopilot
Does anyone have this router, or know enough about it, to tell me is there is a way to manually set the DNS for either an individual device or range of IP’s?
Every router I have had allows this function via the DHCP settings. In this router I can only see it available to set globally per WAN.
You can create VLANs and specify a different DNS server for all devices in that VLAN. I don't know about any DNS override available at the device level.
I have an ER605 as a standby unit in case my main router (Untangle) was to die. It's been a while since I configured it so I'm not up to date with any features they might have added.
Mike
That's not typical for the TP-Link devices I've seen - I don't have a sample of your device - have you reached out to TP-Link customer care or their support forums?
This is a business class router and the cheapest one on the market at $60. This functionality is not needed in business environment with VLAN segmented network. This router is also Omada SDN integrated and some features are not available in stand alone mode.
Yes, only went with this one because it does dual wan so well for the money, it’s been faultless and far better than the Asus I had before that cost 6x more.
I should probably look into getting an Omada controller then as well do you think?
