Hello everyone,
I have this weird behavior happening, ever since I've got the router I've always used the traditional QOS to limit how much certain devices use of bandwidth and without any problem at all, all rules of priority being followed.
5 days ago I have installed Merlin latest firmware to try it out, and it now made my traditional QOS have this weird glitch that a device that has the higher priority, with max bandwidth fall into a lower category. It quite often, I will start a stream and the device instead of having 8mb will have just 3mb which is the a lower priority settings. I even changed the 3mb on the lower priority to 4mb to test it and indeed when I tested it showed 4mb and not 3mb anymore. 1 out of 20 times I try to stream my bandwidth will be capped.
I have no clue what could be causing it, funny enough I have tried to go back to stock firmware and now even there I have this issue. Tried wps reset, factory reset and most stuff I could find online, and now I am pretty much lost on what to do/try.
Any tips would be appreciated.
