traffic analyzer, identify who is it?
Pergola Fabio
hi i see in traffic analyzer a constant down/up from 1MB/2MB
but i dont see what client that is? how to identify it?
thnx
using: RT-AC86U
I see traffic history by device after enabling Traffic Analyzer > Statistic
If your wanting to see what device is actively using bandwidth try checking under Adaptive QOS...Bandwidth Monitor...and then look at clients below. Should see one there with traffic going up and down (technically side to side but you know what I mean). ;)
ok, seems related to chromecast and quic traffic
Glad you found it. Can you share which way helped you find the Chromecast device in case others need to find something similar on their router?
Yes, enabled analyzer, seems my always powered on Chromecast was in idle still downloading...
After Google seems related to the high images for backdrop.... Seems it can download even up to 15gb a month for just downloading images... Well, gonna disable that ;)
