Transmission - lan hard drive
kamil
Is it possible to set Transmission on RC-68u that every files will be saved on hard drive that is connect to router by lan cable (not usb)?
If you can setup a Samba mount to it then in theory is should be able to work. I haven't tested it yet though.
Just verified that it can be done. Syntax for the command is like this:
mount -t cifs \\\\192.168.1.100\\ShareName /mnt/NAS -o "username=nasuser,password=naspassword"
You'll have to create a /mnt/NAS directory or similar prior to running the above command.
You're great! Thank you so much. I also read somewhere about editing fstab - what is the difference between your method and that one with fstab?
I'm not too familiar with fstab so can't really comment.
