SolidSonicTH
I have a ZenWifi AX XT8 running back there and I put in an XT9, hoping that the enhancements would allow me to get closer to my new Internet's bandwidth (I upgraded my modem from a DOCSIS 3.0 to a 3.1 and in doing so my download speed basically doubled).
I'm not expecting to get full bandwidth but when I tested the XT8's performance I only came in at around 430 Mb/s out of a possible ~600, which seemed too low. When I was setting up the XT9 I ran a speed test while it was within line of sight of the core router (a Rapture GT-AX11000 Pro) and I got up to around 560 Mb/s, which is about what I was hoping for, but when I took it back to where I have the XT8 it dropped quite a bit (in fact I think it might be lower than the XT8 in the same spot, although I had both routers hooked up at the same time so maybe they're cross-talking - my next test will be to disable the XT8 entirely and see how the XT9 performs back there by itself).
Was I right in thinking the XT9 would give me a noticeable bump when paired with an GT-AX11000 Pro (since I believe it's able to communicate over the 160 MHz frequency put out by the 11K when the XT8 units can't) or is this too small a jump to get better AiMesh performance and I should consider a superior model if I want improved node bandwidth? I don't know the exact distance between my core router and the placement of my AiMesh node but I estimate it's about 55-60 ft. as the crow flies (and there's a second XT8 AiMesh node in between them in the hall closet).
I also don't mind repositioning the placement of the AiMesh node entirely (I have a bookshelf next to my desk that's considerably higher than the desk where the router is and it's unobstructed as opposed to directly behind a monitor), although if I resort to repositioning the router and suddenly see better speeds I also intend to see how much of an improvement the XT8 gets in that spot and, assuming that's the issue, the XT9 becomes moot and can be returned regardless.
