I am using RT-AX86U Pro - Firmware:3006.102.5
I have one camera device v380 cam which every 5-6 days goes in below loop. Once I reboot the camera, it works fine again for 4-5 days. I have other v380 cams too but they dont experience this issue.
I am looking for some help how to troubleshoot? I have assigned this device static IP at device level and I have assigned same also in my LAN--> Manually Assigned IP around the DHCP list.
This IP is out of DHCP range of the router.
Once I reboot the camera, I get this message in router logs.
hostapd: eth6: STA 1c:bf:ce:55:1f:82 IEEE 802.11: associated
wlceventd: wlceventd_proc_event(722): eth6: Assoc 1C:BF:CE:55:1f:82, status: Successful (0), rssi:-51
wlceventd: wlceventd_proc_event(645): eth6: Deauth_ind 1C:BF:CE:55:1f:82, status: 0, reason: 4-way handshake timeout (f), rssi:-51
wlceventd: wlceventd_proc_event(685): eth6: Auth 1C:BF:CE:55:1f:82, status: Successful (0), rssi:0
wlceventd: wlceventd_proc_event(722): eth6: Assoc 1C:BF:CE:55:1f:82, status: Successful (0), rssi:-52
wlceventd: wlceventd_proc_event(645): eth6: Deauth_ind 1C:BF:CE:55:1f:82, status: 0, reason: 4-way handshake timeout (f), rssi:-52
hostapd: eth6: STA 1c:bf:ce:55:1f:82 RADIUS: starting accounting session 723CF803B870A155
hostapd: eth6: STA 1c:bf:ce:55:1f:82 WPA: pairwise key handshake completed (RSN)
