Right now I have my vpn setup so only 192.168.1.200-192.168.1.249 use vpn.
In addition to that rule the vpn is bypassed if the destination ip is in my ipset.
I'm trying to setup a killswitch that blocks internet access for only the ip's above and only if the destination ip doesn't match my ipset.
I've tried...
But I can't get the ! to work.
I've also tried
But this doesn't stop the internet access when vpn is off.
What am I doing wrong?
I've tried...
# Reject all non white listed connections from vpned ip's from outgoing wan interface.
iptables -I FORWARD -i br0 -m iprange --src-range 192.168.1.200-192.168.1.249 ! -m set --set bypass_vpn dst -o $(nvram get wan_iface) -j REJECT --reject-with icmp-host-prohibited
I've also tried
# Allow whitlisted connections from vpned ip's from outgoing wan interface
iptables -I FORWARD -i br0 -m iprange --src-range 192.168.1.200-192.168.1.249 -m set --set bypass_vpn dst -o $(nvram get wan_iface) -j ALLOW
# Reject all connections from vpned ip's from outgoing wan interface.
iptables -I FORWARD -i br0 -m iprange --src-range 192.168.1.200-192.168.1.249 -o $(nvram get wan_iface) -j REJECT --reject-with icmp-host-prohibited
