Naftali Oziel
How can I find out what is the numeric value of the Mw when I set the tx power adjustment to performance, good etc. ?
The only way is to use an RF power meter.How can I find out what is the numeric value of the Mw when I set the tx power adjustment to performance, good etc. ?
i believe its set in 20% steps , preformance being 100% power output and its dropped by 20% each step down from there
Thanks, but what is the Mw values. e.g. if it's set to 100% is it 80MW?
Blimey, what region are you in!as 2.4 gig is set at 4000mw and 5 gig variable depending on the location but 800mw for the high band
"Good" means moderately violating RF regulations. "Performance" violates more than good.
edit: with heuristics I thought we're talking about one Merlin fork. Apologise if not the case.
Blimey, what region are you in!The router default used to be 80mW on 2.4GHz (max 100mW) and 100mW on 5GHz (max 200mW) - modified downwards depending on region. Don't know what it is now though.
Edit: Sorry I thought the OP was talking about an Asus router. The values are probably different depending on the device in question.
well performance would = max eirp wouldnt it for each channel or close to it , not sure where 80mw comes into it as 2.4 gig is set at 4000mw and 5 gig variable depending on the location but 800mw for the high band
That part of the code is now closed source so there's no way to know.
On HG Gomes' fork 380.59 the % power slider corresponds to these values in mW/dBm. No prizes for guessing which power setting I've chosen![]()
1% => 42mW (16.2 dBm)
25% => 83mW (19.2 dBm)
50% => 178mW (22.5 dBm)
75% => 355mW (25.5 dBm)
100% => 1000mW (30 dBm)
Thread starter | Title | Forum | Replies | Date |
News FCC OPENS ENTIRE 6 GHz BAND TO VERY LOW POWER DEVICE OPERATIONS | General Wi-Fi Discussion | 2 | |
L | Intel BE200 Power Management options | General Wi-Fi Discussion | 0 |
Welcome To SNBForums
