Ubiquiti UCG Fiber with 3 x ASUS XT9 access points
Only if you are happy with flat network design and some management and tuning inconveniences. XT9 doesn't have VLAN support, you can't have network segmentation or guest networks. All wireless related options in Network application will be unavailable. Your Gateway will see all the clients as wired, won't show signal levels to clients, on Tx power change your routers will reboot, InnerSpace application for network planning won't work, etc. Good option to save money and keep you going, but not in a long run. Look at UCG-Max as Gateway alternative. It can do 2.5GbE WAN/LAN, it's a smaller size device, cheaper, may be good enough for your needs.
