Ubiquity U6 lite AP
ALG3013
I mounted my U6 Lite near magnets. I can’t log in now and the unit isn’t broadcasting any more. I think that the firmware was erased. I can ping it at its default ip though. Any thoughts on how I can force firmware via ip address? Thanks!
I'd try a factory reset (hold down reset button for 5-10 seconds), then re-adopt it.
If that doesn't work, it's dead Jim. The magnets likely had nothing to do with it --- surely they aren't using magnetic media to hold firmware in these things. Is it new enough that you could return/exchange it?
I already tried to reset it via reset button x 10sec. multiple times after I noticed broadcast failure. The unit is a few years old and lightly used. I like the overall look and functionality of the unit. I wonder if Ubiquity can help? Thank you all for the response and input.
