uiScribe uiScribe command in post-mount has syntax error
Weblee2407
I noticed some of my logging filters were not running after WAN events or other events where the post-mount script is called. There is a command in post-mount: /jffs/scripts/uiScribe startup "$@" & # uiScribe
that generates an error: "Missing argument for startup, not starting uiScribe"
Any idea what argument is missing? I'm not sure if this is actually an issue because I don't see how it would impact log filters. Scribe is running, but I have to issue scribe reload and scribe restart to get the filters working.
That's exactly what mine says and it works fine.
Are you sure it's post-mount?
When post-mount is invoked by the firmware it should be passing the path of the USB mount point to the post-mount script. Check syslog for how post-mount is being invoked. You can’t just run post-mount manually, in case that’s what you were doing.
yeah, I'm sure it's in post-mount; where is yours? I guess I will uninstall and reinstall.
Yep, I sure was. So that was effective troubleshooting.
No, I meant were you sure that post-mount was causing the issue, but your subsequent posts have answered that.
No, I am not.
D amtm The amtm update command does not work when using 2x WAN. Asuswrt-Merlin AddOns 3
