uiScribe uiScribe installation failed, scribe is not installed
garycnew
All:
When I attempt to install uiScribe using amtm I receive the error: uiScribe installation failed, scribe is not installed.
amtm 6.1.5 by thelonelycoder
GT-AXE11000 (aarch64) Kernel-4.1.52
FW-3004.388.8_4 @ 192.168.0.1
Operation Mode: Wireless router
Thu Jan 15 20:59:07 MST 2026
Please select an option: s
checking syslog-ng daemon ... alive.
syslog.log default location ... /tmp/syslog.log
... & agrees with config file ... okay!
checking system for necessary scribe hooks ...
checking S01syslog-ng ... present.
checking service-event ... present.
checking post-mount ... present.
checking unmount ... present.
checking logrotate cron job ... present.
checking directory links ... present.
checking syslog-ng configuration ...
syslog-ng.conf version check ... in sync. (4.7)
syslog-ng.conf syntax check ... okay!
scribe installed version: v3.2.6 (master)
scribe GitHub version: v3.2.6 (master)
scribe is up to date!
Scribe is clearly installed and appears to be running fine.
What's up with uiScribe?
Thanks.
It’s looking for scribe to be executable.
It appears to be World executable...
# ls -l /opt/bin/scribe
lrwxrwxrwx    1 admin    root            20 Dec  7 16:54 /opt/bin/scribe -> /jffs/scripts/scribe
# ls -l /jffs/scripts/scribe
-rwxr-xr-x    1 admin    root         79649 Jan 15 20:38 /jffs/scripts/scribe
