Release Notes for uiScribe v1.4.7 production version now available
[2025-Jul-05]
1) FIXED: Errors when loading the WebUI page on the 3006.102.x F/W version.
2) FIXED: Issue with "missing scrollbar" on browser windows when the WebUI page was loaded on the 3004.386.14.* F/W version.
3) IMPROVED: Modified code to set the corresponding priority level of log entries when calling the built-in logger utility.
4) IMPROVED: Modified code so that every time the SSH CLI menu is run, it checks if the WebUI page has already been mounted. If not found mounted, the script will run the code to remount the WebUI.
5) IMPROVED: Modified the startup call made in the 'post-mount' script to check if the USB-attached disk partition passed as an argument has indeed Entware installed.
6) IMPROVED: Added "export PATH" statement to give the built-in binaries higher priority than the equivalent Entware binaries.
7) Miscellaneous code improvements.
The fork from @Jack Yaz's uiScribe add-on is now hosted on the AMTM-OSR GitHub repo:
github.com
*NOTE*: uiScribe requires installation of Scribe v3.2.2 (or later) version:
github.com
[2025-Jul-05]
GitHub - AMTM-OSR/uiScribe: uiScribe updates the System Log page to show log files created by Scribe (syslog-ng). Requires Scribe https://github.com/cynicastic/scribe
uiScribe updates the System Log page to show log files created by Scribe (syslog-ng). Requires Scribe https://github.com/cynicastic/scribe - AMTM-OSR/uiScribe
GitHub - AMTM-OSR/scribe: Entware syslog-ng and logrotate installer for Asuswrt-Merlin
Entware syslog-ng and logrotate installer for Asuswrt-Merlin - AMTM-OSR/scribe
