Unable to apply Wireless-Professional settings. 380.63
Andrei Tkachyov
Hello,
When I go to Wireless - Professional settings, I can't apply changes after adjusting any value(s) there anymore with recent 380.x firmware.
Pop-up complains "Please enter a value between -90 to -70" but due to recent changes introduced since somewhere around ~~380.x values for "Tx power adjustment" were changed from numeric to words (Balance/Good/Performance/...)
See screenshot attached please:
Works okay on my AC3200 in router mode.
Have you tried powering the router off for a few minutes and then back on again ?
All the values are validated when you try to change any one. There was a change in the allowed values for Roaming Assistant. Turn on Roaming Assistant and check that the value there is between those limits. Adjust as necessary, then turn Roaming Assistant back off and Apply.
Enabling Roaming Assistant did help!
Thanks!! :)
