Unable to get DNS Director and DNS over TLS working together.
glenw
I have a new RTBE92U router but whenever I activate DND Director DoT stops working. I have read many, many threads and believe all is setup OK. At least it is consistent, I suppose. I can see port 853 only when it's working and 53 when not with "netstat -an | grep :853" and "netstat -an | grep :853".
Can anyone who knows more than me provide some advice to resolve this?
Router: RTBE92U
Firmware: 3006.102.4
DoT to Cloudflare 1.1.1.1, 1.0.0.1, 2606:4700:4700::1111, 2606:4700:4700::1001
LAN DHCP DNS Empty
DNS Director set to "Router"
Many thanks.
Do you have DNS Director set to router?
Yes, thanks.
Then it should work. However, there is a bit of doubt in my mind that the implementation of Stubby (DoT) in this version of firmware is working. You can check Cloudflare Help (https://one.one.one.one/help/) to see if you are connected and if you are using DoT. I would also recommend alternating the IPV6 addresses with the IPV4 addresses in the DoT setup. Stubby alternates the resolvers in the order they are entered.
Cloudflare has a filtered DNS service at 1.1.1.2 and 1.0.0.2 with a TLS Hostname of security.cloudflare-dns.com This is a manual entry but works as well as the 1.1.1.1 and 1.0.0.1 resolvers.
Thanks bbunge,
I also have my doubts that Stubby is working 100% correctly in this version :)
I have used the 1.1.1.1/help page a lot in the last few days (along with the netstat grepping) - this reports DoT all good as long as DNS Director is switched off. As soon as DNS Director is enabled Dot fails. I also had the IPV6 Cloudflare DNS servers in various combinations with and without the IP4 ones. Currenting they are 2 IP4 followed by two IPV6 - 4 in total.
I did also use the .2 variants and the DoT encryption with the name "security.cloudflare-dns.com" but have since gone back to the standard DNS servers, just to remove a potential issue (don't think that is the issue myself).
My conclusion after many iterations is that there is something not quite right with the two working together.
Maybe that is what caused me issues when I tested 3006.102.4.
Disable DoT and try DNS Director. It should work. You can always use DNSSEC. No encryption but DNS verification.
Thanks bbunge,
Cloudflare + DoT + DNS Director shows DoT working on the Cloudflare ‘help’ site for me.
IPv4 & IPv6 servers alternated here.
Enable DNSSEC turned off.
OK, In a command terminal connected to your router run: stubby -l
You should see the DoT connections to the upstream resolvers. I don't thus I suspect something is wrong with both the Asus firmware and Merlin/
Works if DNS are IPV4 - Daemon never loads if IPV6, if mixed fails on IPV6 DNS servers. Stubby reports DNSSEC off even if set to on in GUI.
[05:27:26.950845] STUBBY: Read config from file /etc/stubby/stubby-0.yml
[05:27:26.951473] STUBBY: Stubby version: Stubby 0.4.2
[05:27:26.951584] STUBBY: DNSSEC Validation is OFF
[05:27:26.951609] STUBBY: Transport list is:
[05:27:26.951632] STUBBY: - TLS
[05:27:26.951659] STUBBY: Privacy Usage Profile is Strict (Authentication required)
[05:27:26.951682] STUBBY: (NOTE a Strict Profile only applies when TLS is the ONLY transport!!)
[05:27:26.951705] STUBBY: Starting DAEMON....
[05:27:27.923749] STUBBY: --- SETUP(TLS): : Verify locations loaded
[05:27:27.924263] STUBBY: 1.0.0.2 : Conn opened: TLS - Strict Profile
[05:27:27.944451] STUBBY: 1.0.0.2 : Verify passed : TLS
[05:27:37.009037] STUBBY: 1.0.0.2 : Conn closed: TLS - Resps= 1, Timeouts = 0, Curr_auth =Success, Keepalive(ms)= 9000
[05:27:37.009095] STUBBY: 1.0.0.2 : Upstream : TLS - Resps= 1, Timeouts = 0, Best_auth =Success
[05:27:37.009125] STUBBY: 1.0.0.2 : Upstream : TLS - Conns= 1, Conn_fails= 0, Conn_shuts= 0, Backoffs = 0
Interesting…..
I get the following:
NB, I have DoT set to ‘strict’, go figure…
WARNING: No Stubby config file found... using minimal default config (Opportunistic Usage)
[06:42:11.285569] STUBBY: Stubby version: Stubby 0.4.2
[06:42:11.285697] STUBBY: DNSSEC Validation is OFF
[06:42:11.285737] STUBBY: Transport list is:
[06:42:11.285776] STUBBY: - TLS
[06:42:11.285813] STUBBY: - UDP
[06:42:11.285848] STUBBY: - TCP
[06:42:11.285896] STUBBY: Privacy Usage Profile is Opportunistic
[06:42:11.285934] STUBBY: (NOTE a Strict Profile only applies when TLS is the ONLY transport!!)
[06:42:11.285973] STUBBY: Starting DAEMON....
Interesting…..
I think you need to force stubby to read the config file:
stubby -l -C /etc/stubby/stubby-0.yml
I have been messing around with this (same router on latest Merlin).
It's easy to test (on Windows)), simply run 'nslookup'! It will timeout.
I have found that the bug is related to IPv6!
The bug happens when all of these are true:
  1. DNS director is enabled
  2. DNS over TLS is enabled
  3. One of the servers in the DOT server list contains an IPv6 address!
If I recall correctly @merlin does not have ipv6. That could easily explain why this bug made it into the release.
No problem seen here. I’m using two (Cloudflare) IPv4 servers, + two IPv6 servers + dns director + DoT.
I think Poul Bak may be onto something.
I have found in my case having no IPV6 servers in the DoT server list works reliably for DoT.
BUT - consistently as soon as I enable DNS Director the DoT stops working.
DNS director enabled + DoT enabled + ONLY IPv6 servers enabled and everything here is working fine. Stubby reports all ok, only finds IPv6 servers as expected.
Perhaps this is specific to the RTBE92U and 3006.102.4 Merlin firmware? Is there anyone with this HW/FW combination having DNS Director, DoT, and IPV6 operating together correctly?
