Hello,
I just upgraded my home router from an RT-AC68U to an RT-BE88U.
In the RT-AC68U, the DM was running "just fine," but in the RT-BE88U, I'm not able to install it.
I installed the latest Merlin firmware (3006.102.5), and I’m not able to install the Download Master app on the connected USB drive. (tried formatting as NTFS and ext3)
From the GUI, the error message is simply: "The remote server is not responding."
I have deeply searched this forum and also consulted ChatGPT, but I had no luck
So I tried to debug what’s going on under the hood.
I ran the installation command with debug by connecting via SSH:
and found (I think) that the problem lies with the package repository required to install all the dependent packages.
The error I received is:
I then checked the differences between the packages in the new and old repositories:
New: http://nw-dlcdnet.asus.com/asusware/arm_new/stable/Packages_new.gz
Old: http://nw-dlcdnet.asus.com/asusware/arm/stable/Packages.gz
In the old repo Packages.gz, there are 40 packages:
While in the new repository, there are only 13:
I also tried to add another repo to /opt/etc/ipkg.conf:
Then rebuild available packages with the command:
But it seems that not all packages are compatible with this new hardware.
The incompatible package is (at least) libevent, which was replaced by libevent2, and DM expects libevent, so the installation fails with the error:
This is caused by the lack of the package checked with the script /usr/sbin/app_get_field.sh
Does anybody know how Download Master can be installed on the newer devices?
Thank you!
Bash:
sh -x /usr/sbin/app_install.sh downloadmaster sda
Fail to download the package: pcre!
DM2_Utility, asuslighttpd, downloadmaster, e2fslibs, e2fsprogs, expat, ffmpeg, flac, gdbm, libcurl, asuslibcurl, libevent, libexif, libid3tag, libjpeg, libogg, libpar2, libsigc++, libvorbis, libxml2, ncurses, openssl, asusopenssl, pcre, spawn-fcgi, readline, sqlite, wxbase, zlib, bzip2, aicloud, smartsync, asuswebstorage, inotify, webdavclient, dropboxclient, usbclient, ftpclient, googleclient, sambaclient
DM2_Utility, asuslighttpd, downloadmaster, aicloud, smartsync, asuswebstorage, inotify, webdavclient, asusopenssl, asuslibcurl, ncurses-base, ncurses, wxbase
src/gz entware http://bin.entware.net/armv7sf-k3.2
Bash:
-rf /opt/lib/ipkg/lists/*
ipkg update
/usr/sbin/app_install.sh: line 827: divide by zero
Thank you!
