Skynet Update ban-lists more often
iJorgen
Hi!
If I want to update the ban-lists every 2 hours between 06:00-20:00, would this be the best way to do it?
1. Go to "/jffs/scripts"
2. Edit the file "services-start"
3. Add the line: cru a Skynet_BanUpdate "0 6-20/2 * * * sh /jffs/scripts/firewall banmalware" at the end.
Feels a bit scary to manually edit system-files, so is there a better/safer way to achieve the same result?!
Thanks... :)
