Update Broke 'nvram set dhcp_staticlist'
Kevin K
How do I define a large number of dynamic DHCP addresses and host names like dhcp_staticlist used to do?
Somewhere along the way, it looks like an update made 'nvram set dhcp_staticlist="<MAC>IP>HOSTNAME<MAC>IP>HOSTNAME<MAC>IP>HOSTNAME"' obsolete. As near as I can tell, I'm supposed to put SOMETHING in /jffs/configs/hosts.add and maybe another file in /jffs/configs.
Is there a "How to Migrate from dhcp_staticlist to /jffs/configs" document somewhere?
Hostnames are separated into their own variable now (dhcp_hostnames). Been like that for a few versions.
This was changed in July last year.
384.13 (31-July-2019)
  - CHANGED: dhcp_staticlist no longer contains hostnames, these
             have been moved to dhcp_hostnames for better
             compatibility with upstream and closed source
             components, also allows more static leases to be
             defined before reaching the size limit.
Hope you find this relevant :)
OK. I've seen hints to that effect. I can't tell what I am supposed to *do* in order to convert from the old dhcp_staticlist to the new dhcp_staticlist and dhcp_hostnames.
  • Do I just set both of them the string: <MAC>IP>HOSTNAME<MAC>IP>HOSTNAME<MAC>IP>HOSTNAME
  • Do I set staticlist to: <MAC>IP><MAC>IP><MAC>IP>
  • Do I set hostames to <MAC>HOSTNAME<MAC>HOSTNAME
I get that it changed. What I need help with is finding TFM (so I can RTFM) on what to set staticlist and hostnames to in order to have the same effect -- or what files to put in /jffs and what layout they should have.
Thanks!
OK. I think I've got it. If I delete dhcp_staticlist="<11:22:33:44:55:66>192.168.1.60>fred<22:33:44:55:66:77>192.168.1.61>mary"
I think I can replace it with putting the following lines in /jffs/configs/dnsmasq.conf.add
dhcp-host=11:22:33:44:55:66,fred,192.168.0.60,1440m
dhcp-host=22:33:44:55:66:77,mary,192.168.0.61,1440m
Hmmm... I added those lines and set dnsmasq.conf.add executable. They are getting appended to /etc/dnsmasq.conf. But when I ping fred or mary, I get "ping: bad address". I don't see any errors it /tmp/syslog.log
Arg! I see why nothing DNS is working. The router is doing name resolution using only DNS from the upstream DNS server. It isn't using its own DNS entries. How do I tell the router that when I'm logged in via SSH, it should check its own DNS/nslookup before going to the upstream router?
Tools / Other Settings page “Wan: Use local caching DNS server as system resolver (default: No)”. Set to yes if you really want it to use its own dnsmasq.
I use Winscp to save the files then I can just upload again when needed like after a reset.
Just have to make sure you put them in the correct areas.
Since you are going the dnsmasq.conf.add route (my preferred), you should also consider creating a hosts.add file as well.
Here is a thread where you will find a script towards the end that will create the hosts.add file based on your already existing dnsmasq.conf.add file:
I prefer dnsmasq.conf.add and hosts.add over saving the Asus /jffs/nvram relevant files. Easier to manage and much more portable!
@JGrana, when is your useful script going to be included in amtm? :D
Or, at least menu driven? ;)
