Upgrade Advice
VerizonLover
Currently have a Ubiquit UDM-US that I bought in 2019 from a review that was published here (but that is no longer available).
The latest model is the UDR7, but there are two major problems with it:
  1. 2x2 MU-MIMO on 5ghz vs 4x4 on the UDM
  2. Weaker processor
The problem is that (just like in 2019) the selection of quality routers is a cesspool.
Aside from OpenWRT routers, what are my options?
UDR7 is much newer hardware device with more features and higher performance.
This is the only UniFi AIO device. Your other UniFi options are better specs component system. Otherwise you have to look for something else from the consumer market. AIO home routers - plenty from different vendors. Pick the one you believe fits best your needs.
