UPnP Advertisement Time to Live
Shonk
Is there an nvram setting for
upnp advertisement time to live & upnp advertisement period on merlin
since moving to an arm based router i have found upnp to be nothing but problematic
on both asus and merlin firmware whilst the ac66 was fine
devices are flakey at best seeing it
either that or if someone could point to to where its located in the source to edit
Are you talking about port forwarding (miniupnpd) or the media server (minidlna)?
If it's miniupnpd, try looking at /tmp/etc/upnp/config and
nvram get upnp_ssdp_interval
See the miniupnpd documentation to determine if this is configurable or not. If it is, you can customize the miniupnpd config file through a postconf script.
