upnp & wan disconnect
dahyippur
Everything connected to my ac68u lost internet access this afternoon. Checked the fios website to see no outages. Logged into the router, disabled upnp and everything went back up immediately. Curious if anyone has some insight or sees anything informative in this syslog?
https://pastebin.com/Ym7TaTaX
looks like a dropout or authentication issue on the isp end its not issuing your device with the previous ip address assigned.
I should add, I've turned off upnp based on messages like this repeating in syslog the past week:
Dec 18 18:18:17 miniupnpd[24807]: upnp_event_process_notify: connect(192.168.1.231:2869): Connection timed out
Dec 18 18:18:22 miniupnpd[24807]: upnp_event_process_notify: connect(192.168.1.231:2869): Connection timed out
Dec 18 18:18:41 miniupnpd[24807]: upnp_event_process_notify: connect(192.168.1.231:2869): Connection timed out
Dec 18 18:18:41 miniupnpd[24807]: upnpevents_processfds: 0x2c378, remove subscriber uuid:613642a0-x-x-x-ecda43e0b87b after an ERROR cb: xttp://192.168.1.231:2869/upnp/eventing/fqnwfdmnpn
Which firmware version are you using?
