USB drive mount issue
clvk07
Having some issues with The USB disk attached to the 86U. Disk is called TOURO. I removed the disk from GUI, unplugged the disk, rebooted router but still shows up in mnt. If I attach the disk, it gets mounted as TOURO(1) but I cant see any data from the router. If I map the drive in windows as TOURO(1) I can see the data. Any ideas?
Below info after removing the drive still shows up as TOURO
admin@RT-AC86U-4960:/tmp/mnt# ls
TOURO sda1
admin@RT-AC86U-4960:/tmp/mnt# df
Filesystem 1K-blocks Used Available Use% Mounted on
tmpfs 220208 1824 218384 1% /tmp
/dev/mtdblock8 49152 11444 37708 23% /jffs
/dev/sda1 14779860 1668320 12344360 12% /tmp/mnt/sda1
tmpfs 220208 1824 218384 1% /www/index_style.css
tmpfs 220208 1824 218384 1% /www/require/modules/menuTree.js
TOURO sda1
EDIT:
Could try;
umount -f -l /tmp/mnt/sda1
