Use 2nd 5GHz radio for DMZ?
Bamsefar
So I have a AC3200 router, with dual 5GHz radios. Is it possible to use 2nd radio for DMZ? I have two devices from work that I need to direct connect to work without opening a lot of ports that I do not like to expose for my private devices....
It may be possible with some scripting (anyone?).
But that won't give you a direct connection to your work, rather, it will expose those two devices to everyone on the 'net.
VPN.
Hmm You are of course correct - it will only expose internet to the PCs - not the other way around which is what I am after...
