Using Cat 6 UTP connector on Cat 6a STP wire?
SDISB
I already have a bunch of cat 6 UTP connectors but the contractor actually installed cat 6a STP instead of UTP. Any cons to installing UTP connectors on STP cables? And should I buy some STP connectors instead?
Ideally you should use STP connectors with STP cables to ensure the shield doesn't act like a giant EMI antennae. STP connectors with UTP cable is not usually an issue.
Thanks. I did crimped a few with UTP for testing. If it is for testing then it is fine right?
randomName Best CAT cable to block RFI and EMI? Switches, NICs and cabling 8
