DNScrypt Using DNSrypt with Nordvpn on RT-ac68u or other DNS security tools
Galaxysurfer
I am new to tinkering with DNS. What has started this quest is issues with my Linux os MX Linux. I am currently using an RT-AC68U configured with AMTM Diversion, Skynet, Yazfi & Entware along with a few of the logging scripts. I have been getting no internet available messages on Linux. I am sure there is something that needs tweaked from that end to address the symlink etc. This got me thinking about better ways to secure my dns data. I have blocked the google dns by routing it to gateway. This leaves only the gateway as nameserver in my resolv.config file. I have routed to Nordvpn servers which they suggest to mitigate DNS leaks. In light of the fact that Nordvpn was bought by Surfshark, I want to do things a bit different to protect my data & not rely on one or more tools alone. What are my best options here using my particular router model etc? How to I switch to other DNS servers & keep the dns from being leaked? What are the best dns server options - OpenDNS Cloudflare or Quad9 etc? I dont have resources to host own dns resolver or nameserver nor would I want to necessarily. Will DNSCrypt meet that challenge or do other tools need to be brought in as well? Thanx in advance for any feedback & suggestions.
PS What about Unbound in the mix? As someone else commented "Our routers can only do so much." I don't want to put it all on one device necessarily.
Hi Galaxy! I'm not on here much, but when I saw dnscrypt and needing help, I had to check it out. Long time user of it myself.
I'm running w/ exact same router and thought this might could be helpful to you. From the main page, right after you first login, Click on Tools, then Other Settings.
Tools->Other Settings
At the bottom, change
To YES.
Afterwards, I turn my VPN clients settings from
to
Followed by a reboot (sometimes I don't need to, but I would reboot anyways to make sure it sticks if your power goes out or you need to reboot it later)
I hope this helps. God bless.
