Using E-4200 and WNDR3700 and its lightning fast
cc666
This what I did and it works perfectly:
E-4200 as AP
WNDR 3700 as router
on WNDR 3700:
disable PNP
Disable 2.4 and 5.0 wireless
Set up DHCP reservations on 11 connections
DHCP 192.168.1.2 - .198
enable IPV6
on E-4200:
LAN out to LAN in on WNDR3700
Disable DHCP
Set router ip at 192.168.1.199 (Set IP OUT OF DHCP range of the WNDR3700)
Disable NAT
Set up wireless with WPA-2 AES
disable PNP
Passes stealth on Shields up, I can access all shares including a wireless printer. Lightning fast! IPV6 also works perfectly.
Charlie C
K Using a mesh system as a wireless access point General Wi-Fi Discussion 8
