Vendor class identifier
khris972
hello
I need to send the vendor class identifier to my provider, tomato or dd-wrt I use -V "xxxxxxxxx" and it works
asus merlin wrt (manual clientid) in it does not work, can you help me thank you ?
Asus recently changed their dhcp client, so it's not as straightforward as back when they were using the same dhcp client as Tomato.
Whats about this idea now?
It is very necessary feature.
PS And what correct udhcpc command with -V option for your firmware?
Thx, but what about support this feather in Merlin firmware?
And what about right udhcpc command?
What is wrong here? ("vlan2: No such process" cause wan0 status is "disconnected")
/tmp$ udhcpc -b -i vlan2 -p /var/run/udhcpc2.pid -V sml7105-rt
udhcpc (v1.20.2) started
Nothing to flush.
Nothing to flush.
Sending discover...
Sending select for 172.23.131.228...
Lease of 172.23.131.228 obtained, lease time 10800
Nothing to flush.
Nothing to flush.
RTNETLINK answers: No such file or directory
You need to provide more information about your setup.
What router are you using?
What firmware version.
How are you connected to the internet (i.e. cable, 3g USB modem, etc.)
Where did you get this command from (udhcpc -b -i vlan2 -p /var/run/udhcpc2.pid -V sml7105-rt)?
I`m sorry.
N66U, of course. 3.0.0.4.374.36_beta1-sdk5.
DualWan mode. Wan as wan0, lan4 as wan1.
Wan0 (vlan2) connect to ISP router at lan4 with IPTV only.
Wan1 (vlan3) connect to ISP router at lan1 with Internet only.
ISP DHCP demand specific VendorId for lease IP-adress. Elsewhere IP-adress is not lease. This command via SSH do it.
Sorry, I don't have a setup anything like that to compare it with.
Just for info, what do you currently get when you issue this command:
# ps w | grep udhcpc
Thx for your patients, but I am tired to drill my rt66u and buy zyxel. It router have solutions for my problem.
PS But configure VendorId in Asus - good idea for todo list.
