Vertical stand for Ax88uPro
Tomo
Hi, i was wondering if anyone mounts the Ax88uPro vertically?
At the moment i have an AC86U and where i mounted it i don't have much horizontal space and i was seeing if anyone had mounted it with some vertical stand.
The alternative was the Ax86uPro model but i liked the 88 model better especially from a future perspective.
If you do a search, there are people that have made various 3D printed stands for Asus routers, there might be one suitable for your needs.
I only found it for the old ax88 and from what i saw it might not be compatible due to the different layout of the eth ports
You can make brackets from shelf rack and bend it for holding bottom of router & with small z bracket for holding top router against falling over.
Here's picture of my router on wall with lan ports.
Nice job!!!
