VPN Director Question
sirzur
In the VPN director page, is it possible to add a rule to direct access to a domain to WAN?
The reason why I am attempting that is to allow Voice over Wifi (VoWifi) to work together with VPN. I have discovered that in order for VoWifi to work on a phone which is directed through VPN, I need to make sure that traffic to the VoWifi DNS host is going through the WAN. In my situation for the carrier that I am with, the DNS host is epdg.epc.mnc001.mcc505.pub.3gppnetwork.org and also epdg.epc.mnc071.mcc505.pub.3gppnetwork.org. I have used the nsloopup website and determined the IP address of the two DNS host (which has 4 IP addresses for each URL, ie. a total of 8). So I was wondering whether there is any way to enter the URL rather than IP address in VPN director. Or even with a wild card like *.pub.3gppnetwork.org rather than IP address
Here is a screenshot of my VPN director rule showing the 8 IP address
Use of a domain name won't work because the underlying mechanism for such routing is based on ip rules, which do NOT take a domain name.
ip rule add to 149.135.224.26 table main
I suppose it's possible to write your own script to update the VPN Director by resolving those domain names and adding the ip rules yourself, perhaps w/ each reboot or update of the firewall. It can still be a bit tricky since you have to ensure proper placement/priority within the list of existing ip rules in order to maintain proper precedence.
BTW, in a case like this, it's often simpler and usually safe to treat these resolved domains as class C domains.
149.135.226.0/24
149.135.232.0/24
149.135.233.0/24
101.168.246.0/24
Not a huge difference in this particular case, but can sometimes dramatically reduce the number of rules.
Frankly, I would recommend NOT routing the VOIP adapter through the VPN in the first place, thus you could base the rule on the single source IP of the VOIP adapter. I don't like having VOIP on the VPN for this and other reasons (e.g., I don't want to risk dropped calls since a VPN is typically less reliable than your ISP connection).
Thanks and I appreciate the detailed response to my question. Looks like I will just live with the rules, but maybe have the 5 you recommend instead of the 8 that I have.
I too agree that the VOIP adapter should not be routed through VPN. I actually routed my VOIP ATA adapter through the WAN when I was running a "landline". But because of the imminent shutdown of 3G network, Voice over LTE (VoLTE) and Voice over Wifi (VoWifi) has been implemented by my mobile/handphone/cellphone provider for phone calls. So the VoLTE and VoWifi is through my Android phone, which I also use for browsing the internet and also has multiple banking and government services app. I therefore prefer to use this through the VPN.
I could turn the VoWifi off (and just use VoLTE) because I live and travel in city areas where there is good cell coverage. That would be a workaround to keep VoLTE. I noticed that with VoWifi on, if the Vowifi cannot be connected, the phone has a hissy fit and also shuts down VoLTE ie. I can't even make a call.
I had actually considered another option for you, but there appears to be a bug preventing it.
Oh, thanks for this. I will await the response to your question with interest. That is an elegant solution
