Puck6T9
I have look for days, but can't find a post that is the same as my problem. So I'm going to ask for help. This may sound dumb, but I'm at a loss on it.
I have a VPN server up & running. Using the ipv4 address i can connect just fine to it. But if i try using my ipv6 address it just times out when outside the network. Inside the network it connects. I know what my WAN ipv6 is & what my ipv6 block assigned to me by my isp is. But neather address will connect remotely. What is the ipv6 address i use? What am I missing that is preventing the connection?
On a sperate question, i have a 4g hotspot. According to the provider the ipv4 is private, but it supports ipv6 & they clam the ipv6 is public. I can belive it becouse when the xbox is connected to it & using ipv6 it shows a open NAT & no firewalls. Now my Asus rt3200 can use this hotspot as a usb modem. But i have to run the ipv6 on the Asus in passthrough mode. Is there a way to run a VPN, or any remote network access, by using the ipv6 on the hotspot. The hotspot has a setting to allow incoming ipv6 connections.
Thanks for any help any one can provide. Im normally good with networking, but I'm at a loss on my ipv6 issues .
