Netbug
I got a new router RT-BE92U coming from RT-AC86U.
I've installed the latest merlin firmware (3006.102.4), reset via web gui and via hard reset (holding down WPS button whilst turning on router), set it up like i would on my old router but having a strange issue.
I have two open vpn clients setup on my router one vpn is on client 1 (gb) and another vpn on client 3 (nl), my client 3 vpn works fine, my client 1 vpn does not work, just says Error - check configuration! .
I redownloaded new openvpn config files from my provider and setup like i always do and never had an issue before plus my client 3 vpn works just fine.
I go to the logs file and below is what it shows for my client 1 vpn. It shows an error but not sure what to do to fix it, my providers servers are up and working and only happening on the client 1 (gb) vpn, i reset it to defaults multiple times, restarted router multiple times and still same issue.
Any help appreciated as i'm at a loss why the one client works and the other does not.
Removed log as issue now solved
