worldburger
I’m in the market for a VPN router. Wasn’t sure if this should have gone in the wireless buying advice section since it’s VPN specific. Feel free to correct if need be.
I’ve used client side VPN, but was curious about router vpn after reading the great reviews for the RT-AC86U while using vpn on the router.
I had wanted to simply purchase this model and be done with this as it looks to be such a great router. BUT I was trying to find a similar router that had tri-band. The reason for this being so I could use the 2nd 5Ghz as the wireless connection on the EX8000 extender to get a bit more coverage as well as hookup a gaming device that would benefit from the EX8000’s Ethernet connection (which is far away from the router and cannot be hardwired directly).
GT-AC5300 (BCM4908)
TP-Link Archer C4000 (BCM4908)
R8000P (BCM4906)
R7900P (Costco’s R8000P) (BCM4906)
EA9300 (BCM4908)
I have gigabit service, so a higher VPN speed would be nice. Possibly 10-20 devices total on the networks. Very old construction house. 3 stories + basement. I have considered mostly routers that could be used with Merlin, but as turnkey as possible is probably more ideal for my ignorance on a lot of the technical setup.
Current hardware: Netgear X6 (R7900) on ground floor.
I’ve narrowed in on these:
GT-AC5300 (BCM4908)
R8000P (BCM4906)
EA9300 (BCM4908)
EA9500 v2 (BCM4908)
EA9400 v2 (BCM4908)
EA9400 v2 (BCM4908)
As I understand it, these Broadcom processors *should* give a better VPN performance similar to how the RT-AC86U gets such good VPN performance. Am I understanding that correctly?
Which of these would be advised?
Or would there be negligible impact simply going with the RT-AC86U with the EX8000?
I could use some advice. I’m sure I’ve left out some material information, so ask away if more details would be helpful.
First post, go easy
Thanks in advance!
First post, go easy
Side note: the people in this forum (and Tim’s reviews) are amazing. I’ve benefited a ton over the years just reading which is a testament to the efforts of all that are active here, so thank you all!
