vpn_clientX_state=-1
Viktor Jaep
Part of the Furniture
Every so often, something weird glitches on my GT-AX6000... and one of my unused VPN slot states is listed as "-1". Typically, they are either 0 (off) or 2 (on)... 1 would be (connecting). Any idea what the -1 means? I guess something else I'll need to check for in order to try to force reset it back to 0... ;(
nvram show | grep vpn_client3_state
vpn_client3_state=-1
nvram show | grep vpn_client2_state
vpn_client2_state=2
nvram show | grep vpn_client1_state
vpn_client1_state=0
-1 means there was an error. Can be a config error, incorrect certificate, failure to connect, etc...
