vsftpd uses 32-bit capabilities
this warning relates to the capabilities of the Linux kernel that Asus uses for their devices. The vsftpd-2.0.4 source hasn't been patched correctly. The fix is to add the line:
#undef VSF_SYSDEP_HAVE_CAPABILITIES
#define VSF_SYSDEP_HAVE_LINUX_SENDFILE
#define VSF_SYSDEP_HAVE_LIBCAP
to the vsftpd-2.0.4/sysdeputil.c source code file. This warning is still in the latest vsftpd v3.0.2, which I have patched before compiling Merlin's source code. After the patch, the syslog warning no longer occurs.
I am seeing this warning on my RT-68C running the latest Merlin FW 380.64.
+1 same to me with AC88U running Merlin FW 380.64
Please where is the file located?
Thank you! Happy New Year!
kernel: warning: `vsftpd' uses 32-bit capabilities (legacy support in use)
Not really a bug per se - it's just a statement in the log reminding the devs at some point to rebuild it for 64-bit.
There's still a lot of legacy 32-bit code in the newer AsusWRT builds - they've ported over the "important" stuff on a case by case basis where performance can be improved.
Only the RT-AC86U and GT-AC5300 have 64-bit CPUs, so everything is 32-bit.
The only exception with these two routers is Strongswan, probably so it can properly interface with the 64-bit kernel crypto modules.
Hello,
Today , i get the same warning on my RT-AX86U Pro with AsusMerlin 3004.388.4 ???
Nov 7 19:38:59 kernel: capability: warning: `vsftpd' uses 32-bit capabilities (legacy support in use)
