Hello everyone, I configured my ASUS RT-AC87U with "Merlin"-Firmware that I can reach it from WAN and did a Portforwart to the PC which I want to wake up. I also set a static ARP-Entry for that PC with a script. Everything works fine - but when I start (connect) the VPN-Client of the Router WOW doesn't work :-( (DDNS is updateted to the new VPN-IP!). When I disconnect the VPN and update DDNS WOW works fine!
I did the same config with the same router an "dd-wrt" on it - also connected the VPN-Client - WOW works fine
But I want to get it to work with Merlin Firmware
Has anybody a idea what the problem is? Thank you so much!
