WAN PORT Speeds
trameltanz
I have an Asus RT-AC88U router with a Netgear CM1150V cable modem.
The Router is running 384.13 Merlin - I am concerned only with WIRED connections at this time. All devices have their latest OS and Driver updates.
I am paying for 500+ download with Comcast/xFinity
When my PC is connected (wired) to the modem speed tests show 500+mb/s download. When the PC is connected to the router's LAN I am getting 300mb/s download.
All devices, phones, tablets, PCs, wired, wireless, etc...all behave the same way as far as download speed.
I did some google-ing and found out that the WAN port in the AC88U usually pegs out above 800mb/s.
Right now I am using cat5e cables for everything.
I have tried both Asus stock firmware and Merlin's and they both behave exactly the same.
I have turned off AiProtection, QoS, traffic analyzer, and NAT Acceleration.
Asus GUI says that the WAN port is connected 1GB and all LAN ports are connected 1GB.
1. Will a Cat6/7 patch cable improve performance from the WAN port on the router to the Uplink on the Cable Modem?
2. Is there a limitation in the firmware for the WAN port in the Router?
3. Am I missing any configs for the Asus Router?
Any help is appreciated! Thank you!
I have tried NAT Acceleration both ON and OFF
This setting has never made a difference in speed....until now!
Well, sure as there is ice in my freezer I am not getting about 450mb/s down
