WAN Restart from shell
pm22
Hi!
How can i restart the WAN connection from the shell?
Background: I have a 3G internet connection using a Huawei E372 stick. My provider kicks me out every 24 hours. The asus router reconnects immediately, so that's no problem. But i want to move the reconnect into the night. My idea is a cron job which restarts the WAN connection at 05:00.
A great feature would be, if i can configure that with the WebGui ;-)
Hi!
Go to the main page, click on the WAN icon. On the right you will have a toggle switch to disable/enable WAN.
Hi !
Yes, i know that button, but i have to do it manually. I want that it will be performed automatically at a configurable time.
If i can make a restart from the WAN with a shell command, i can implement this function in my scripts.
BTW: Thank you for your great firmware!
Simple!
just type the following command:
service stop_wan
service start_wan
or :
service restart_wan
Hi where I type in it?
What software do I need to connect?
THX
EDIT : It´s possible to make with Telnet?
