wan-start never get called
bogolisk
Hi
I put a wan-start script on the router but it never get called. If I telnet in and call the script by hand then it's ok. But it never get called when wan ip changed.
admin@router:/tmp/home/root# ll -t /jffs/scripts/wan-start
-rwxrwxrwx    1 admin    root           128 May 24 11:34 /jffs/scripts/wan-start*
admin@router:/tmp/home/root# cat /jffs/scripts/wan-start
#!/bin/sh
wget -q http://freedns.afraid.org/dynamic/update.php?xxxxxxxxxxxxxxxxxxxxxx -O /tmp/freedns.out
system log
May 29 13:33:32 pppd[30651]: Connection terminated.
May 29 13:33:32 pppd[30651]: Sent PADT
May 29 13:33:32 pppd[30651]: Modem hangup
May 29 13:33:42 pppd[30651]: PPP session is 577 (0x241)
May 29 13:33:42 pppd[30651]: Connected to xx:xx:xx:xx:xx:xx via interface eth0
May 29 13:33:42 pppd[30651]: Using interface ppp0
May 29 13:33:42 pppd[30651]: Connect: ppp0 <--> eth0
May 29 13:33:43 pppd[30651]: PAP authentication succeeded
May 29 13:33:43 pppd[30651]: peer from calling number xx:xx:xx:xx:xx:xx authorized
May 29 13:33:43 miniupnpd[30733]: Failed to get IP for interface ppp0
May 29 13:33:43 miniupnpd[30733]: SendNATPMPPublicAddressChangeNotification: cannot get public IP address, stopping
May 29 13:33:43 pppd[30651]: local  IP address 66.36.xx.xx
May 29 13:33:43 pppd[30651]: remote IP address 204.19.xx.xx
May 29 13:33:43 pppd[30651]: primary   DNS address xx.xx.6.230
May 29 13:33:43 pppd[30651]: secondary DNS address xx.xx.54.230
May 29 13:33:43 dnsmasq[28549]: read /etc/hosts - 5 addresses
May 29 13:33:43 dnsmasq[28549]: read /etc/hosts.dnsmasq - 17 addresses
May 29 13:33:43 dnsmasq-dhcp[28549]: read /etc/ethers - 17 addresses
May 29 13:33:43 dnsmasq[28549]: using nameserver xx.xx.6.230#53
May 29 13:33:43 dnsmasq[28549]: using nameserver xx.xx.54.230#53
May 29 13:33:43 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
May 29 13:33:43 dnsmasq[28549]: exiting on receipt of SIGTERM
May 29 13:33:43 dnsmasq[28577]: started, version 2.69 cachesize 1500
May 29 13:33:43 dnsmasq[28577]: asynchronous logging enabled, queue limit is 5 messages
May 29 13:33:43 dnsmasq-dhcp[28577]: DHCP, IP range 192.168.1.200 -- 192.168.1.254, lease time 1d
May 29 13:33:43 dnsmasq-dhcp[28577]: DHCP, sockets bound exclusively to interface br0
May 29 13:33:43 dnsmasq[28577]: read /etc/hosts - 5 addresses
May 29 13:33:43 dnsmasq[28577]: read /etc/hosts.dnsmasq - 17 addresses
May 29 13:33:43 dnsmasq-dhcp[28577]: read /etc/ethers - 17 addresses
May 29 13:33:43 dnsmasq[28577]: using nameserver xx.xx.6.230#53
May 29 13:33:43 dnsmasq[28577]: using nameserver xx.xx.54.230#53
May 29 13:33:43 rc_service: ip-up 28557:notify_rc stop_upnp
May 29 13:33:43 miniupnpd[30733]: shutting down MiniUPnPd
May 29 13:33:43 rc_service: ip-up 28557:notify_rc start_upnp
May 29 13:33:44 miniupnpd[28593]: HTTP listening on port 35400
May 29 13:33:44 miniupnpd[28593]: Listening for NAT-PMP/PCP traffic on port 5351
May 29 13:33:47 WAN Connection: WAN was restored.
any idea?
bogo
any idea how to debug this? can anyone point me to the place where wan-start get called? /etc/xxx???? or /rom/etc/xxx ???
Thanx
Start by writing a message to syslog at the beginning of your script to see if it is being executed.
#!/bin/sh
logger -t $(basename $0) $1
#!/bin/sh
Wow, just adding that line make it work!!! must be a timing thing. Maybe ppp0 is not fully functional when wan-start got called and calling logger made it work by adding a delay.
Thank you very much.
