Want to move away from Asus routers, Ubiquiti? advice needed
after discovering this Unifi stuff
It's addictive. Single 3-in-1 gateway, one extra PoE switch eventually, few APs, few cameras. This is all you need. Reddit if full of UniFi "home lab" setup pictures, it's like a competition who is going to spend more money for no reason. Some run equipment similar to the one used for the chemical plant in Lawrence Systems video. 🧐
But then, 4 days later, the 6+ AP is $20 off.
If I remember correctly your gateway was UGC-Ultra. There is a new U7-Lite access point for $99. Dual-band, unlikely to exceed Gigabit on Wi-Fi, perhaps will be good fit for Gigabit gateway. What it may give you more - system integration, easy configuration changes with no reboots, SSID to VLAN in few clicks, better looks perhaps. If your Asus router in AP Mode is working fine though - no rush.
Thanks, yes that makes sense. Would that still be a thing if all the IoT stuff is on it’s own network? What kind of threats are we talking about from IoT devices? It would just be 2 or maybe 3 cameras max, and they would be wired. 👍
This depends on what kind of threats you're worried about and how far down the rabbit hole you want to go. AIUI the main concerns in this area are:
  • If your security cams connect via wifi, they can be disabled by a burglar who has a wifi jammer. Some say that's becoming a common tool for miscreants to carry.
  • OTOH, if your cams connect over wires, then anybody who can shimmy up to an outside camera and unplug it can plug in their own device and have access to your LAN.
  • On the third hand, if somebody has broken into your LAN some other way, they could gain access to your camera footage, or maybe attack the cams directly.
The point of putting cams on a separate VLAN is that it offers some protection against both of the latter threats: jacking into a camera feed doesn't give access to your whole LAN, nor can someone easily get access to the cameras from some other part of the LAN.
My take is that the average homeowner probably is wasting their time/money to worry about any of these scenarios. But if you've spent money on security cams in the first place, maybe you feel like worrying.
A matter of choice and specifications comparison. UCG-Fiber has better Gateway and Switch parts inside, better NVR options with SSD storage, separate AP allows better placement, etc. UDR7 on the other hand is cheaper, takes less space... perhaps better option for someone looking for a single AIO device in a smaller coverage area. In terms of software both are identical or very similar.
Indeed. I think you do get that with pretty much anything computer related, it always turns into a 'mine is bigger than yours' contest. Add in social media and that just fuels it. But, if it makes them happy...😂
Correction: Seems like UCG-Fiber does have a cooling fan inside, @user1234567890.
Performance tests and thermals information here:
I haven't heard anything so far, and I'm sat a few feet away from it. I think it's probably preferable to have a fan, especially if you never hear it. I haven't seen anyone do teardown of these kinds of things, I'd be interested to see what's inside.
There's quite a high crime rate where we live, so a visual deterrent is better than none, for sure. Always good to be secure, thanks for the info 👍
@cptnoblivious, seems like with the new per App/Category QoS presets in Network Application 9.1.120 our UGC-Ultra can do about 450Mbps WAN-LAN. Ubiquiti is warning about performance impact and this is what I see happening on our gateway model. Just sharing quick test results in case you are interested in QoS. @user1234567890, your UCG-Fiber gateway will go faster.
Thanks, that's still way faster than my internet connection (sadly). But I appreciate the heads-up :)
I enabled QoS right now as we WFH but only for Teams and Zoom. If it's a nuisance I'll just turn QoS off again.
If QoS is really needed you can experiment with per App/Category QoS in Routing/QoS section (which perhaps uses DPI for traffic identification), but also with Smart Queues in Internet/WAN section (which applies FQ-CoDeL AQM).
Run some more tests, it's around 450Mbps with IDS + QoS, around 550Mbps with QoS only and close to Gigabit with IDS only.
Was that for me?
If so, not needed, you misunderstood. My internet connection is < 450 Mbps. So speed reduction is not an issue or concern :)
U7 lite installed, and all up and running. Very impressed overall. Just a few loose ends to tie up, like if you have an IoT SSID, how does that stop them spying on you if they are connected to the same network, just a different SSID? There must be a way to stop that, but I've not found it yet. Flex mini keeps disconnecting, not sure why, tried the original psi and a samsung charger of the same specs and it's pretty much the same, so going to return it and get something else, but not sure what. Thanks for all the help, it is much appreciated 👍
Some people isolate the IoTs on different VLAN, some prefer convenience and keep them on the main VLAN. Cloud connected speakers, microphones, cameras, door bells, light switches - they were brought home by the user, didn't come uninvited.
@user1234567890 you could break out what IoT devices actually _need_ to live on the same network as your 'standard' devices. If they don't off they go onto a VLAN.
I run a VLAN just for corporate devices (laptops and phones that connect to wifi) as I don't want them on my main network. As an example, those also get different DNS servers for less filtering compared to personal devices.
YMMV. :)
I'm tempted with the Cloud Gateway Ultra, but seeing reports of slow speeds for people who use PPoE for the net connection. Topping out at 700~ instead of the usual 900~
Not sure if this is fully resolved or not. Hmm.
