Warning in the client file
xlarge
I have lived with this for years, but like to solve the problem now.
Hope for solution. See pics of client1.ovpn and result during install.
The answer is literally given to you in the warning message you highlighted.
Thank you, but where can I find auth-nocache option? Nothing like this in VPN server advanced. Only these seems to have with authentication to do.
TLS control channel security (tls-auth / tls-crypt) I use Disable.
HMAC Authentication I use Default.
Looking into both i found no auth-nocache option.
As the comment above said, you can either edit the client1.ovpn file directly or use the router's VPN Server "Custom Configuration" box and put it there (and then re-export the file).
