I'm having weird problems with my 2.4 Ghz network after upgrading replacing stock firmware with Merlin 378.55 on my Asus RT-AC68P. If I go to the wireless general and professional page, the only option in the dropdown is 5Ghz. If I try to select a channel the dropdown options start at 36. If I hover over the little SSID indicator at the top of the administration page, it says 2.4 Ghz is on channel 36 and 5 Ghz is on channel 0. If I disable my Mac Filter and go to site survey it says the 5ghz radio is disabled, but it only shows me 5ghz networks. On my Mac wireless diagnostic utility, it says my Mac is connected to a 5Ghz network with the same SSID as my 2.4 Ghz network (even though my 5Ghz SSID has is different than the 2.4 Ghz SSID). My daughters Windows 8 laptop can't see our network at all, I suspect because it is on channel 36, but I can't find a way to change it to a lower channel. At one point I did see normal 2.4 GHz channels in the dropdown, but now I can only get 36 and above (36, 40, 44, 48, 149, 153, 157, 161, 165). I tried changing my bandwidth to 20 MHz and it did not help. Interestingly, if I click on the 2.4 Ghz SSID link at the top, it takes me to a wireless general page that has different settings, including SSID then the 5Ghz link does, so there does appear to be both settings; they just can't be accessed via the band dropdown. then the Has anyone seen this behavior? Does anyone know how to set the 2.4 Ghz channel through SSH if the webapp is not working?
