Tutorial Change Wireless settings that have improved TimeMachine stability
iTyPsIDg
I recently made some changes to my Wireless settings (General and Professional pages) which have significantly improved the stability of my TimeMachine backups. I have two USB drives attached to my router. I use one for Entware and the other as a NAS (I know, I shouldn't. I will eventually get a real NAS, but that isn't an option right now).
I live in an apartment with other Wifi networks nearby. I'm sharing this for two reasons: 1) Selfish - I can use it to reconfigure my setup if I have to factory reset, and 2) it might help others who have experienced issues.
On the General tab, the big thing was to stick to 20 MHz due to the nearby traffic. Also, I learned that adjacent-channel interference is worse than co-channel interference. My neighbors aren't respecting the 1/6/11 rule. I initially thought 11 was best because the signals were weaker around that channel, but it had more adjacent-channel interference.
For Professional 2.4 GHz, I made the following changes:
Preamble type: Short (recommended for busy networks)
DTIM Interval: 3 (increasing to 3 helps battery life on mobile devices without major impact)
Optimize AMPDU aggregation: Enable (can enhance efficiency)
Airtime Fairness: Disable (can sometimes cause issues)
OFDMA (802.11ax): Disable due to how crowded the band is in my area
Universal Beamforming: Disable (not useful in most scenarios)
For Professional 5 GHz, I made the following changes:
OFDMA (802.11ax): DL/UL OFDMA + MU-MIMO (OFDMA is excellent for my low-throughput devices (smartwatches, Kindles, IoT) and MU-MIMO is helpful for devices requesting large streams (Zoom, FireTV)
You effectively limited your 2.4GHz band to AX capable clients only. AMPDU aggregation may increase throughput, but also latency and may break time sensitive data.
That's problably ok - as most recent Macs support 11ax, and there is benefit to 11ax in 2.4 that cannot be denied...
WiFi DTIM=3 is good for all Apple devices in my experience.
My concern is TimeMachine on AsusWRT - one is asking for a lot of trouble, as the implementation there is older than old - you won't know until you try to restore backed up data.
Apple Silicon Macs don't use Apple Share File Protocol (Netatalk) and the sparsebundles don't use HFS+ any longer... There's only two ways I suggest TimeMachine support these days - either direct attached storage over APFS, of if needed to support devices over a LAN, is to use a Mac with attached storage there...
It's bad enough that I no longer recommend using older TimeCapsules and AirportExtremes with USB attached drives - one cannot trust the backups - and the AsusWRT and others that have reverse engineered them...
it's your data - TimeMachine might not be your friend...
11ax over 2.4 might be a good discussion over on the general wireless thread - seriously, I've kind of been waiting on that one, and getting prepped to support that discussion with both QCA and MTK platforms, along with Broadcom and Intel clients...
After experiencing persistent instability issues, I discontinued using ASUS Time Machine several years ago. I subsequently explored various alternative solutions, but none of them proved to be reliable. I have been using an external SSD for the past several years and my MacBook Time Machine backups have been exceptionally reliable.
I'm not using the TimeMachine option directly on AsusWRT, what I use does support APFS. Here is my method: https://www.snbforums.com/threads/t...macos-big-sur-and-monterey.76232/#post-731686
I agree that this isn't the best solution long term, but I am not currently in a situation where I can have a NAS because I am a digital nomad. This method allows me to have something.
I think the only items I have that use 2.4GHz are my Kindles and the apartment's smart fridge and they seem to be working fine.
