Weird Messages on RT-AC66U
web-ninja
I am getting these messages in the log file. There is no Linux or Mac running anywhere on this network. Do you think the network is being compromised?
Apr 10 08:03:27 smbd[6438]: [2015/04/10 08:03:27.383496, 0] smbd/sesssetup.c:1355(reply_sesssetup_and_X)
Apr 10 08:03:27 smbd[6438]: reply_sesssetup_and_X: Rejecting attempt at SPNEGO session setup when it was not negotiated.
Apr 10 08:03:27 smbd[6439]: [2015/04/10 08:03:27.394473, 0] smbd/sesssetup.c:1355(reply_sesssetup_and_X)
Apr 10 08:03:27 smbd[6439]: reply_sesssetup_and_X: Rejecting attempt at SPNEGO session setup when it was not negotiated
The error message indicates there is a missing security parameter for ntlvm2 with a Samba share. See this post: http://forums.gentoo.org/viewtopic-t-840743-start-0.html
Are you using the same user account on your Samba share as you are when trying to set up the share on our AC66?
For more info on this, you might want to look at this blog posting: http://office-supply-liberation.blogspot.com/2014/01/asus-ac66r-wireless-router-mounting.html
Alternatively, if you're not intending to set up a Samba share, then you probably want to just go into the GUI, go to "USB Application-->Network Place (Samba Share)-AI Cloud" and turn off the Samba share altogether. That should stop the messages completely.
I have just started getting this on my RT-AC88U
since i put my RT-AC66U in AP mode on the lan
before the RT-AC66U it was fine
Apr 6 17:19:01 smbd[1032]: [2016/04/06 17:19:01.710682, 0] smbd/sesssetup.c:1355(reply_sesssetup_and_X)
Apr 6 17:19:01 smbd[1032]: reply_sesssetup_and_X: Rejecting attempt at SPNEGO session setup when it was not negotiated.
Apr 6 17:23:06 smbd[1045]: [2016/04/06 17:23:06.517002, 0] smbd/sesssetup.c:1355(reply_sesssetup_and_X)
Apr 6 17:23:06 smbd[1045]: reply_sesssetup_and_X: Rejecting attempt at SPNEGO session setup when it was not negotiated.
Apr 6 17:49:12 smbd[1064]: [2016/04/06 17:49:12.223052, 0] smbd/sesssetup.c:1355(reply_sesssetup_and_X)
Apr 6 17:49:12 smbd[1064]: reply_sesssetup_and_X: Rejecting attempt at SPNEGO session setup when it was not negotiated.
Apr 6 17:53:20 smbd[1071]: [2016/04/06 17:53:20.583622, 0] smbd/sesssetup.c:1355(reply_sesssetup_and_X)
Apr 6 17:53:20 smbd[1071]: reply_sesssetup_and_X: Rejecting attempt at SPNEGO session setup when it was not negotiated.
Apr 6 18:00:11 disk_monitor: Got SIGALRM...
Apr 6 18:06:07 smbd[1084]: [2016/04/06 18:06:07.571278, 0] smbd/sesssetup.c:1355(reply_sesssetup_and_X)
Apr 6 18:06:07 smbd[1084]: reply_sesssetup_and_X: Rejecting attempt at SPNEGO session setup when it was not negotiated.
