What am I doing if I block Google public DNS?
OzarkEdge
Part of the Furniture
I'm getting bored here waiting for a firmware update to debug...
So, I set static routes to block Google public DNS 8.8.8.8 and 8.8.4.4. My router LAN IP is 192.168.1.1; router DoT is 94.140.14.14, 94.140.15.15, dns.adguard-dns.com. From my wired PC at 192.168.1.184, Win11 Terminal ping reports:
Pinging 8.8.8.8 with 32 bytes of data:
Reply from 192.168.1.1: Destination host unreachable.
Ping statistics for 8.8.8.8:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
A small accomplishment of uncertain value.
Now, if my wired Google TV on my guest VLAN (192.168.52.*; Mode Access) or any wireless client on my guest VLAN (Access Intranet disabled; DHCP Server enabled using 192.168.52.*; AP Isolated disabled) attempts to use Google DNS... what have I accomplished?
I figure I should learn more about these things because BIG DATA seems to be pushing further into our homes... now Walmart owns Visio and requires Visio TV owners to log into a Walmart account to use their Visio TV (I don't own a Visio TV). I see no end to this invasion of our castles.
OE
Main reason I used the LAN > Route setting to block Google DNS's is to prevent devices or apps that may have Google's DNS hard coded from bypassing my Pi-Holes. Once in a blue moon I'll see the Pi-Hole query log show a device or app trying to bypass the Pi-Holes and get re-routed due to the route block on Google.
fax 802.1Q (VLAN) under WAN and LAN-IPTV under LAN, doing the same job?? ASUS Wi-Fi 1
