What router?
Thanks. So is "band1" the same as Band A UNII-1 Lower (Channels 36 – 48)? Or is it the entire Band A? Perhaps the string in the Merlin firmware could be changed to something more standard rather than the confusing "band1" that doesn't lead to any good search hits.
I didn't put that there, it's from Asus.
Not blaming you in any wayJust trying to understand what it really means and whether the Merlin firmware could use an alternate string that better explains what it means.
I think it means 'include DFS channels'
Not been worded correctly, translation error maybe?
No, it cannot be changed. It is hard coded in boot loader of router. I should add few version back you could override, however not anymore.Is there a way there you can get an option to choose whether you want extended channels or not in all FW
Interestingly, my RT-AC68U shows correct string (FW: Merlin 378.54_2)
EU vs US router? Different rules/options depending on where your are.Strange. I run the exact same version and mine looks like the screenshot in the first post. How can this be?
Yes, there is country code and regulation revision info that is copied from the bootloader to nvram.Is the info stored somewhere in the bootloader?
etz@Kari-AP:/tmp/home/root# nvram get pci/1/1/ccode
etz@Kari-AP:/tmp/home/root# nvram get pci/2/1/ccode
etz@Kari-AP:/tmp/home/root# nvram get wl0_country_code
EU
etz@Kari-AP:/tmp/home/root# nvram get wl1_country_code
EU
etz@Kari-AP:/tmp/home/root# nvram get regulation_domain
etz@Kari-AP:/tmp/home/root# nvram get regulation_domain_5G
Thread starter | Title | Forum | Replies | Date |
M | Frimware Broke Router - 2.4ghz now showing channels 1 - 14; both wifi 5 showing 36 - 165. Help! | Asuswrt-Merlin | 21 |
Welcome To SNBForums
