Just upgraded from an AC66U to an AC3100 and this is my first experience with a dual core router. I have gigabit fiber so I can put a pretty heavy load on the router just from routing. When pegging the bandwidth by downloading something on a client computer I've noticed only the first core (Core 0) is pegged or high usage. The second core barely moves from 0%. Is this normal? I was expecting the load to be balanced between the two cores.
Random info if it helps: I don't use VPN, HW Acceleration is Enabled, CTF (cut through forwarding) is active, and I have VLAN tagging on the WAN port using IPoE (not PPPoE). I am running Merlin's firmware.
